Max overclock for GTX645
Go to solution Solved by harrynowl,
determined by gpu and voltage limits. just crank slider until it doesn't work in games anymore and back off from there.
as gtx645 is an oem card (likely alienware) you probably wont get much from it
My GTX 645 runs at 30C at 50% load, and at max load 50C plus the fan doesn't ramp up from 30%, if i overclock i could make it run at 50% or 90%
CPU: i7 4770 GPU: GTX Asus 760 CASE: Zalman Z11 Blue COOLER: CoolerMaster Hyper 212 STORAGE: 2TB Toshiba Hard Drive 120 GB SSD
https://linustechtips.com/topic/206064-max-overclock-for-gtx645/
https://linustechtips.com/topic/206064-max-overclock-for-gtx645/#findComment-2798633
