Could something go wrong with my hardware if i remove my case side panels? Like dust? I get better temperatures with them removed.
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/205573-case-side-panels-removed/
There's dust... And there's the cat...
Keep the cat away at all costs...
https://linustechtips.com/topic/205573-case-side-panels-removed/#findComment-2790849
You have a very capable case as far as air cooling is concerned, I'm guessing you're just using the 2 stock 120mm fans though. I'd highly recommend buying some new fans.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/205573-case-side-panels-removed/#findComment-2791386
