Location? I'm guessing USA.
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2788696
if I were you, I would go for something a little bit more expensive.  The problem that I am with right now is that when I first built my computer,  I got a cheap case.  But now (1.5 - 2 years later) I want to upgrade my GPU.  But the GPUs that I am looking at are to big for my case.  If you go to around $80 you can get a pretty sweet and almost future proof case (Depending on what you are planning to do).  In the end you would be saving your self the money.
Good luck!
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2789025
Good luck!
What do you prefer in that price range
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2789924
The NZXT Phantom 410
  • Plenty of fan options
  • Removable drive bays ( so you can take out what you don't need and improve the airflow.)
  • Dual 120mm radiator.
  • Can fit up to 11in to 16.5 inches graphics cards!
  • Nice cable management.
  • Water cooling grommets at the back of the case.
  • Nice looks, and comes in multiple colors.
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2791758
<p>
But ickey plastic
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2791760
That's just a matter of personal opinion. My friend has this case and it very nice. Good build quality, and pretty sweet looking in my on opinion of course.
The red is the worst.
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2791832
That.... I will have to agree on.
The plastic is so srachable, and does not match the metal color
https://linustechtips.com/topic/205426-right-case-for-me/#findComment-2791845
