hey LTT members
I bought a new Asrock B85M HDS 3 days ago,and it works fine, but when I unplug the power cable from the pc and replug it, the pc boots several time like the first boot after building a pc, I think it's a mobo problem. So what do you think of that ? is it a mobo problem ? and is it a critical problem ? and how can I solve it ?
and my secend problem is that my pc freezes randomly, about 1 time a day  the temps and memorie usage andspeed are normal , and now I'm running a memetest, what do you think of this problem ?
PS I've never overclocket anything, and every thing are set in normal setting
https://linustechtips.com/topic/205401-boot-problem-and-pc-freezes/
how many sticks of RAM are installed?
run with one stick
ensure the power plugs to the mobo are secure
a lose power plug will cause the repeat power cycles
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
run with one stick
I'm using one stick of Hyperx fury 8gb?
Do you mean 24 pins cable or 8 pins cable ?
btw how much circles or time should I run the memetest for ?
yea either the 24 pin and 8 pins
run for a few hours of the memtest say around 4-6 hours
btw what PSU you got in your system?
I'm using corsair cx500
do the memtest and see what you get
I have run it for 2 hours with no error, and I may let it running for more 4 hours to see what I'll get
yea will wait for your result
Clear CMOS and check the power cables again
do you have another PSU to test?
try the paper clip test for the PSU
if the PSU is ok
i may point to mobo problems
if the PSU is ok
I think the psu is ok
I'll try a Tacens Mars 700 ( it works just fine for more than 2 years in an other pc )
and  I'll clear CMOS
BTW the pc freezes randomly sometimes it happen after 4 or even 6 hours after booting the pc, so testing the pc after these changes may take the hole day
looks like mobo trouble
you might need to replace it
