Need help installing drivers
By
Gert
in Troubleshooting
in Troubleshooting
Solved by dragoon20005,
there should be an .exe installer when you download them
or the other method is go to device manager and select the wifi adaptor and click update driver
located the drive .inf file in the driver folder that you download and it will install the correct drivers
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
3
derekchan ·
Posted in New Builds and Planning7 -
6
5
7
kerriya ·
Posted in Cases and Mods13
play_circle_filled
Latest From ShortCircuit:
