Hello I'm planning on doing a new gaming/working pc this is what i have gathered until now:
http://pcpartpicker.com/p/4K2sVn
(storage is going to be diferent)
i need your opinion on the setup and how to make it better without making it more expencive (other possibilities).
https://linustechtips.com/topic/204476-i-need-advice/
By working, do you mean professional video editing, or CAD/3d modelling?
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/204476-i-need-advice/#findComment-2776433
SKIPPER, don't get the 4GB version. you will see no fps improvement
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
https://linustechtips.com/topic/204476-i-need-advice/#findComment-2776451
oh and my advice would be not to get that aio water cooler, it will make A LOT of noise during heavy load. get a top end air cooler instead like the noctua nh-d15
https://linustechtips.com/topic/204476-i-need-advice/#findComment-2776498
i've been researching about amd vs nvidea and i have found that nvidea for work has better compatibility than amd thats why I was avoiding AMD (correct me if i'm wrong)
For gaming I'd use Crossfire 290 but for editing (If you use CUDA) then definetly Nvidia
https://linustechtips.com/topic/204476-i-need-advice/#findComment-2776677
