Hey guys, I've noticed that when im on desktop my GPU load hits 90% and over - (temp hitting 81 degrees)
Any way to solve this? I've tried using guru3D to uninstall and install my gpu driver
The only temp solution i've found was to just update/install my drivers to 340.52 although Im already using that version
Thanks ! btw Palit GTX760
[edit] is it possible that it's overclocked without me knowing?
https://linustechtips.com/topic/204218-90-gpu-load-when-idle-help/
scan your computer for any virus
might be a mining virus
also could be PSU trouble
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Got any programs running in the background?
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
I used malwarebytes and it said that I dont have any malware etc on my pc
if you got a spare PC
dump the GPU there to verify if it not your PC problems
should I just keep installing my graphics driver everytime i use my pc LOL xD
it def not normal
check your windows services
check the task manager for any unusual process
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
