Hey everyone.
I have a problem when trying to livestream on twitch.
My audio and my cam are always getting out of sync.
In the beginning of the stream everything is correct but one hour later my audio is starting to delay around a 300ms.
When I fix it then by delaying my webcam 300ms another hour later it is again out of sync..
Does anyone have any idea how to solve this issue?
I'm using a logitech c930e for my webcam
a blue yeti microphone
software:
obs
adobe audition
virtual audio cable
https://linustechtips.com/topic/203386-livestream-audio-problem/
Hey everyone.
software:
obs
adobe audition
virtual audio cable
I assume its because you're using multiple pieces of software, Can you use your capture application's settings and use that to host your mic. Instead of using other applications, just to see if that solves your issue.
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/203386-livestream-audio-problem/#findComment-2761097
