Those are the parts i have already bought and I have 400-500 dollars left to spend. I need a graphics card, cpu, cpu cooler and dvd drive. I cant figure out what would be the best set up with that budget. Overclocking would be nice to have. Thanks in advance!!!!
ps all parts must be from newegg or a different reputable company that will ship in the u.s.
https://linustechtips.com/topic/2033-need-help-cpu-cpu-coller-graphics-card/
You'll probably want to get an FX-6300, 8GB DDR3 1600 G.Skill Sniper RAM or Ripjaws X, a Radeon HD 7870, a Cooler Master Hyper 212 EVO, and a $20 ASUS DVD burner. That power supply is not a very good quality unit though. Something from Corsair or SeaSonic is extremely preferable. You definitely should have come here initially though, or at least figured out what all your parts would be before you bought half of them. Buying your components at different times, ok, but buying them without even knowing what the other ones are was not a good move.
There is no way you'll get a graphics card, CPU and RAM for $200 that can overclock and is decent for gaming which is what I assume this is for. If you want to stick to the $200 budget then you're limited to the AMD Athlon X2 270 ($50), Kingston value RAM 4GB ($30) and some form of Radeon 7750 + a CM 212 Evo CPU cooler ($30).
You never ever ever ever ever ever ever ever start buying parts for a computer until you've planned out the system because it'll cost you more in the long run.
EDIT: I swear that said $200 the first time I read it. Anyway; AMD FX 4100 or FX6100, something like a 7850 or 7870, CM 212 Evo, 8GB Corsair Vengeance low profile, cheap DVD burner..
what he said!
| Contact Information |
My Teamspeak : Austs1.gameservers.com:9334  |  Steam: Iamtictac456  |  My other aliases include Scruffy and Scruffy Biggems :)
[TABLE=class: innerCells, width: 0]
[TR=class: cartHeader]
Savings
Total Price
[/TR]
[TR=class: cartItem]
[TD=class: cartSelect, bgcolor: #F2F2F2]
[/TD]
[TD=class: cartQty, bgcolor: #F2F2F2]
[/TD]
[TD=class: cartDescription, bgcolor: #F2F2F2]
GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video ...
Item #: N82E16814125418
Return Policy: VGA Standard Return Policy
[h=3]Protect Your Investment (expand for options)[/h]
[/TD]
[TD=class: cartSavings, bgcolor: #F2F2F2]
-$10.00 Instant[/TD]
[TD=class: cartPrice, bgcolor: #F2F2F2]
$259.99
$249.99
[/TD]
[/TR]
[/TD]
[/TD]
G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model F3-8500CL7S-4GBRL
Item #: N82E16820231307
Return Policy: Memory Standard Return Policy
[/TD]
[/TD]
$41.98
($20.99 each)
[/TD]
[/TR]
[/TD]
[/TD]
AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8350FRHKBOX
Item #: N82E16819113284
Return Policy: CPU Replacement Only Return Policy
[/TD]
[/TD]
$199.99
[/TD]
[/TR]
[/TD]
[/TD]
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
Item #: N82E16835103099
Return Policy: Standard Return Policy
[/TD]
-$8.00 Instant
$5.00 Mail-in
[/TD]
[/TR]
[/TABLE]
will these be good?
Savings
Total Price
[/TR]
[/TD]
[/TD]
[/TD]
$259.99
$249.99
[/TD]
[/TR]
[/TD]
[/TD]
[/TD]
[/TD]
$41.98
($20.99 each)
[/TD]
[/TR]
[/TD]
[/TD]
[/TD]
[/TD]
$199.99
[/TD]
[/TR]
[/TD]
[/TD]
[/TD]
-$8.00 Instant
$5.00 Mail-in
[/TD]
[/TR]
[/TABLE]
will these be good?
or should i go for a different graphics card?
