I would definitely worry mate. If that thing leaks, it'll damage your motherboard.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/203202-h100i-possible-leak/#findComment-2758591
Its already two years old, no warranty for me!
Possible solution?
Maybe ill start off with isolating it with electric isolation tape?
And, should I send this to corsair? I mean, this happened by itself maybe its a recurring problem and who knows what they can do
https://linustechtips.com/topic/203202-h100i-possible-leak/#findComment-2758798
Possible solution?
if i were you i would send it back because as soon as that starts to leak it will leak on the the GPU possibly causing a short so use the stock cooler for the time being.
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/203202-h100i-possible-leak/#findComment-2759094
It happens to alot of h80/h100i's the rubber is just there for aesthetics,to hide the hose crimping (http://forum.corsair.com/forums/showthread.php?t=120418 ,corsair rep at post 8)
They claim it's safe , but they will replace it if you have it in warranty, if you don't trust it, then you could get zip ties on them
https://linustechtips.com/topic/203202-h100i-possible-leak/#findComment-2760721
