The stock fans are very cheap and loud, trust me.
Also, unless you're going for looks over sound, don't get the SP's. Noctuas and noise blocker would work well too.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2754605
Those are the quiet editions. And noctua are so much more and they don't pre from much better.
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2754619
I have 5 quiet editions and they're not quiet. I'm not sure what qualification you have to speak on this but I have had 5 noctuas but the looks drove me insane so I bought the quiets. Before, at full speed, I could not hear the noctuas at all. The quiets are very audible. Trade off for the looks though.
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2754636
Akasa Apache Blacks are an excellent option, they have great static pressure and are very quiet. Other great options include Be Quiet Shadow Wings, Noiceblockers, NF-F fans, Gentle Typhoons (if you can get them) and Bitfenix Spectre Pros.
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2754684
sp 120 performance edition works great on my h100i
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2757855
SP120s are terrible, I got them, I regret buying them so much. They look nice, but that's it
Yeah, I'm more a power user. People regard SP120s as being awesome fans because of their strike between being quiet and decent ability to push air around. But since I don't care that my fans sound as loud as jet engines, the SP120s are a terrible choice for performance compared to what else I can find.
Max out the RPMs on this: http://www.frozencpu.com/products/11111/fan-709/Akasa_120mm_x_25mm_Viper_PWM_Fan_w_Hydro_Dynamic_Bearings_AK-FN059.html and  you've got a better, cheaper fan..
bloomfield is teh bes >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2759781
Yeah I know, but those look terrible though. I'm happy with the aesthetics of the SP120s, but that's really all.
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2761203
Welp, future black and yellow watercooling build is going to love em.
Just some searching will find you some more. The JetFlo 120s, although not really that SP optimized, still get a decent SP when the RPM is maxed out.
https://linustechtips.com/topic/202928-h100i-fan-replacements/#findComment-2761259
