when i look at the rpms of my fans, the fans that are on my radiator is spinning at almost 4000 rpm which makes it very noisy, while the other fans stays at approximately 1000-2000 rpms. which is accaptable for my taste.so the question is, why is the radiator fans almost double the rpm ?
https://linustechtips.com/topic/202507-liquid-cooling-fans-issues/
i see you have an asus motherboard, you should be able to get the ai suit software from their website and control the fans in your system better
heres the link to ai suit v 1.00.56 from the asus website which is the newest one listed in the utilities downloads for your mother board
http://dlcdnet.asus.com/pub/ASUS/misc/utils/AISuite3_Win7-8-8-1_M6G_VER10056.zip
Perhaps use a "Low noise adapter"?
and what fans are you using that have this high rpm issue? and
what platform are you using to monitor this?
thx!
i have noctua fans, and im using the BIOS to monitor
