Anyone know if I can remove the top decorative caps to make it 2mm shorter to fit in a case?
https://linustechtips.com/topic/201746-cooler-master-tpc-612/
Only one way to find out. ;)
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2735852
If there is a will there is a way. You might have to do a little serious modding but it should work :)
Sorry not much experience with this case.
CPU cooler*
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2735853
I don't want to break mine
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2735855
Those are the end of the heat pipes. If you were to take them off you would completely ruin the cooler.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2736005
No, it has caps on the end of the end of the heat pipe, for a decorative look instead of the look of something like a 212 evo
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2736012
If there's no easy way to take them off then I don't think Cooler Master would have wanted you to take them off in the first place.
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2736027
I'll see if there is an easy way
https://linustechtips.com/topic/201746-cooler-master-tpc-612/#findComment-2736038
