Power Supply troubleshooting
Solved by SlayerOfHellWyrm,
The tolerance for the +12V rail is ±5%. Therefore, the +12V raile is considered within tolerance if the voltage reads from 11.4V - 12.6V. Anything outside of that range is unacceptable, and the PSU is beginning to fail. You should purchase a new one ASAP. As for 24/7 operation, that's not ideal for normal PSU's, however, it's not worth getting a server PSU for a media centre. If you can, I suggest using Wake on Lan on all connected devices, so the media PC simply shifts into sleep when it's not being used, which will greatly extend the lifespan of it. If you can't, manually put it into sleep, there's no need for it to be 100% on, and idle, 24/7, and that will definitely shorten your PSU life span.
