Hey, I was just wondering if my first new build will be worth Overclocking and when to do it .
Specs:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£239.94 @ Aria PC)
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler (£63.00 @ Amazon UK)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard (£154.76 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2133 Memory (£126.19 @ Scan.co.uk)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive (£81.71 @ Amazon UK)
Storage: Western Digital Red 2TB 3.5" 5400RPM Internal Hard Drive (£68.53 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 780 3GB WINDFORCE Video Card (£369.99 @ Amazon UK)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case (£84.98 @ Novatech)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply (£94.99 @ Amazon UK)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£11.21 @ Aria PC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£79.46 @ Amazon UK)
Other: NZXT Internal USB Expansion (£13.99)
Total: £1388.75
Cheers Josh
https://linustechtips.com/topic/201384-overclocking-first-build/
Everything looks solid, but I'd go for the WD black HDD as the red is mainly for NAS
Also I'd prefer to spend a bit more on an H100i CPU cooler instead of H80
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730075
Note: When is the RIGHT TIME to Overclock
When you make sure everything works PROPERLY, especially CPU, mobo and CPU cooler
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730084
You should overclock when it's necessary to lengthen the time your system will be able to maintain high settings/framerates in modern games and future releases. That system won't need to be overclocked for some time. That being said the motherboard and power supply are overkill and it would be better to get a 240mm AIO instead of a 120mm AIO. In addition RED drives are meant for NAS usage and while you can use them just fine something like a barracuda or a WD blue might be cheaper.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730099
I agree with this, either a WD Blue or black would be better. There's no point in the H80 since it's minimally cheaper than the H100.
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730149
Hey @JoshTBG. About the HDD I'm with the guys from the community. If you plan on running most of your demanding programs/games from the SSD, a WD Blue drive might suit you better or a WD Green if you're set on 2TB, because for now the WD Blue goes up to 1TB. But if you need high performance from your HDD - the WD Black is the way to go. It depends solely on your needs and budget. I wouldn't recommend the WD Red, for general usage as their main purpose is NAS systems as @Lord Pantaloons correctly mentioned. Here are some links where you can find more about the drives and pick the one you think best fits your configuration:
WD Blue: http://www.wdc.com/en/products/products.aspx?id=770
WD Green: http://www.wdc.com/en/products/products.aspx?id=780
WD Black: http://www.wdc.com/en/products/products.aspx?id=760
Hope that helps.
Cheers,
Boogieman_WD
WD Representative
http://www.wdc.com
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730495
Whats NAS?
Sorry @RockiLocky, I saw your post right after I posted mine. NAS means network-attached storage. Basically NAS devices are servers which are dedicated to file sharing with massive storage capacities, with hard drives connected in a RAID system. And here's some info on RAID: http://www.tomshardware.co.uk/answers/id-1856981/raid.html
Boogieman_WD
WD Representative
http://www.wdc.com
https://linustechtips.com/topic/201384-overclocking-first-build/#findComment-2730574
