Help on CPU heatsink
Solved by Thorium19,
the 650W PSU is fine for now, no need to change it.
the DarkRock 3 is a very good mid range air cooler, similar performance to the noctua NH-U12S/14S, albeit slightly cheaper I find. It will allow you to get a decent overclock on your 6300 and keep temperatures to a good level, even under load, unless you put a lot of Vcore through it and have a massive overclock on it.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
16
