First time planning build Need Help !
Solved by TheRunningOtaku,
Cpu throttle? I could force an ssd to happend but with the current budget i may have to take some loan in oder that to happend could you recommend an good ssd drive for me to buy ?
Do you think you could afford an SSD soon?
What I'd suggest (and what Linus suggests a lot) is getting the SSD (MX100, 256GB, $110) first, then waiting a bit and getting the HDD later when you have the cash, or vice versa. But if you get a HDD first you'll have to reinstall windows.
Then after that when you have more cash you can throw on a proper cooler.
These problems (Lack of an SSD and CPU cooler) while still problems, aren't worth getting a loan for.
