Overclocking G3258 Help
Go to solution Solved by afluffehbunneh,
http://hwbot.org/newsflash/2127_msi_oc_on_z87_h87_b85_and_h81_chipsets_z87_the_only_true_overclocking_platform <-- this was actually in the video
MSI have basically denounced H81/B85 overclocking and used the latest microcode on their motherboards.
The video has misinformed a few now as you're not  the first.
I imagine 6.6 has the new microcode, 6.5 did not. However as far as I know downgrading the BIOS will not downgrade the microcode. You'd need to use FTK.
I am very proud to announce that you.....are very incorrect. In the most polite and upstanding way, you just tried to misinform me :(
Luckily I am extremely hardheaded and went on after reading your post. Turns out it is actually quite simple for the rest of the people with this problem here is your solution...you might laugh at yourself...I did:
1. Open BIOS (If you don't know how to do this....leave)
2. Go to the Overclock Menu (Labeled OC on the left hand side)
3. In the Overclock menu there will be several different clock speeds all grayed out, misleading that they cannot be altered.
When you reach this page you should see a subheading that says "CPU Ratio" and it will be set to "Auto". this confused me because it did not have Brackets "[Auto]" like the others. If you click the "Auto" text and then type numbers it will change your frequency. (Remember "Numbers" x 100 MHz, i.e 40 = 4 GHz)
To my surprise I saved, restarted, and Tada my readings are now 4 GHz.....Good luck...and have fun Overclocking.
Managed to get to 4.3 GHz on my Rig without crashes. Still stress testing, however, seems stable with initial tests.
No matter where I have looked, or what I have tried....I cannot find a way to overclock the 20th anniversary G3258 Intel Processor. I read somewhere that the processor could be overclocked to upwards of 4.7GHz being a $70 processor. I bought the CPU because I thought it would be an awesome choice (after overclocked of course) for gaming if it could hit the core clock speeds that were stated.
However, I have found it almost impossible to overclock this chip. I turn to the community to help me out with this. The reason I chose this forum and not another is because of how fond I am of the constant tech reviews. I built this PC on the basis of this video:
https://www.youtube.com/watch?v=rtLVktnzO2M
Where the custom build states that the motherboard I have can now overclock the cpu.
Granted my specs are different when it comes to GPU and RAM (RAM is different because I got bad chips on an order and waiting for them to be replaced).
Specs:
CPU: Intel® Pentium® CPU G3258 @ 3.20GHz
Motherboard: MSI H81M-E33 (MS-7817)    Bios V 6.6   (This version had an update for G3258!!)
Memory: DDR3 4 GBytes
Graphics: AMD Radeon HD 7970
https://linustechtips.com/topic/200223-overclocking-g3258-help/
DXDiag Info:
System Information
Time of this report: 8/20/2014, 07:31:40
       Machine name: GLADOS-PC
   Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
           Language: English (Regional Setting: English)
System Manufacturer: MSI
       System Model: MS-7817
               BIOS: BIOS Date: 07/22/14 09:35:23 Ver: V6.6B0
          Processor: Intel® Pentium® CPU G3258 @ 3.20GHz (2 CPUs), ~3.2GHz
             Memory: 4096MB RAM
Available OS Memory: 4040MB RAM
          Page File: 2870MB used, 5208MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: AMD Radeon HD 7900 Series
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon Graphics Processor (0x6798)
           DAC type: Internal DAC(400MHz)
         Device Key: Enum\PCI\VEN_1002&DEV_6798&SUBSYS_0B001002&REV_00
     Display Memory: 726 MB
   Dedicated Memory: 3058 MB
      Shared Memory: 1764 MB
       Current Mode: 1280 x 1024 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: LCD1735NXM
         Monitor Id: NEC6653
        Native Mode: 1280 x 1024(p) (60.020Hz)
        Output Type: DVI
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1280 (English)
     Driver Version: 14.100.0.0
        DDI Version: 11
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 4/17/2014 22:42:54, 1343272 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71EE2-24D8-11CF-B276-0A2BBEC2C535}
          Vendor ID: 0x1002
          Device ID: 0x6798
          SubSys ID: 0x0B001002
        Revision ID: 0x0000
 Driver Strong Name: oem12.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R575:14.100.0.0:pci\ven_1002&dev_6798
     Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (3- Logitech G930 Headset)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: USB\VID_046D&PID_0A1F&REV_0100&MI_00
        Manufacturer ID: 65535
             Product ID: 65535
                   Type: WDM
            Driver Name: USBAUDIO.sys
         Driver Version: 6.01.7601.17514 (English)
            WHQL Logo'd: Yes
          Date and Size: 11/20/2010 06:43:52, 109696 bytes
            Other Files:
        Driver Provider: Logitech, Inc.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX 2.0 Listen/Src: No, No
   I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Sound Capture Devices
            Description: Microphone (3- Logitech G930 Headset)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Audio Controls
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A1F
        FF Driver: n/a
      Device Name: USB Receiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52B
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x8C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x8000
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
+ HID Keyboard Device
| Vendor/Product ID: 0x046D, 0xC232
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC231
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 83.3 GB
Total Space: 152.5 GB
File System: NTFS
      Model: ST3160815AS ATA Device
      Drive: D:
      Model: PHILIPS SPD2513P ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_8C20&SUBSYS_D8171462&REV_05\3&11583659&0&D8
   Driver: n/a
     Name: Intel® 8 Series/C220 Series PCI Express Root Port #4 - 8C16
Device ID: PCI\VEN_8086&DEV_8C16&SUBSYS_78171462&REV_D5\3&11583659&0&E3
   Driver: n/a
     Name: Intel® H81 LPC Controller - 8C5C
Device ID: PCI\VEN_8086&DEV_8C5C&SUBSYS_78171462&REV_05\3&11583659&0&F8
   Driver: n/a
     Name: Intel® 8 Series/C220 Series PCI Express Root Port #3 - 8C14
Device ID: PCI\VEN_8086&DEV_8C14&SUBSYS_78171462&REV_D5\3&11583659&0&E2
   Driver: n/a
     Name: Realtek PCIe GBE Family Controller #4
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_34687470&REV_06\4&1C376A0C&0&00E3
   Driver: n/a
     Name: Intel® Management Engine Interface
Device ID: PCI\VEN_8086&DEV_8C3A&SUBSYS_78171462&REV_04\3&11583659&0&B0
   Driver: n/a
     Name: Intel® 8 Series/C220 Series PCI Express Root Port #1 - 8C10
Device ID: PCI\VEN_8086&DEV_8C10&SUBSYS_78171462&REV_D5\3&11583659&0&E0
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_AAA0&SUBSYS_AAA01002&REV_00\4&1610F4F8&0&0108
   Driver: n/a
     Name: Universal Serial Bus (USB) Controller
Device ID: PCI\VEN_8086&DEV_8C31&SUBSYS_78171462&REV_05\3&11583659&0&A0
   Driver: n/a
     Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_8086&DEV_8C02&SUBSYS_78171462&REV_05\3&11583659&0&FA
   Driver: n/a
     Name: AMD Radeon HD 7900 Series
Device ID: PCI\VEN_1002&DEV_6798&SUBSYS_0B001002&REV_00\4&1610F4F8&0&0008
   Driver: n/a
     Name: Intel® 8 Series/C220 Series USB EHCI #2 - 8C2D
Device ID: PCI\VEN_8086&DEV_8C2D&SUBSYS_78171462&REV_05\3&11583659&0&D0
   Driver: n/a
     Name: Intel® Xeon® processor E3-1200 v3/4th Gen Core processor PCI Express x16 Controller - 0C01
Device ID: PCI\VEN_8086&DEV_0C01&SUBSYS_78171462&REV_06\3&11583659&0&08
   Driver: n/a
     Name: Intel® 8 Series/C220 Series USB EHCI #1 - 8C26
Device ID: PCI\VEN_8086&DEV_8C26&SUBSYS_78171462&REV_05\3&11583659&0&E8
   Driver: n/a
     Name: Intel® 4th Gen Core processor DRAM Controller - 0C00
Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_78171462&REV_06\3&11583659&0&00
   Driver: n/a
     Name: Intel® 8 Series/C220 Series SMBus Controller - 8C22
Device ID: PCI\VEN_8086&DEV_8C22&SUBSYS_78171462&REV_05\3&11583659&0&FB
   Driver: n/a
     Name: Realtek PCIe GBE Family Controller #3
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_78171462&REV_0C\4&2BCECA6C&0&00E2
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
ATI MPEG File Writer,0x00200000,1,0,atimpenc.dll,13.30.0000.40417
AMD Video Decoder,0x00200000,1,2,atimpenc.dll,13.30.0000.40417
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,13.30.0000.40417
AMD MJPEG Decoder,0x00200000,1,1,atimpenc.dll,13.30.0000.40417
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
AMD Video Encoder,0x00200000,1,1,atimpenc.dll,13.30.0000.40417
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc.dll,13.30.0000.40417
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
AMD Video Scaler Filter,0x00200000,1,1,atimpenc.dll,13.30.0000.40417
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
AMD Video Rotation Filter,0x00200000,1,1,atimpenc.dll,13.30.0000.40417
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (3- Logitech G930 He,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
USB Audio Device,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (3- Logitech G930 Head,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (3- Logitech G930 Headset),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-2714012
The problem is he uses a z97 which doesnt help me much with my H81........
I've seen that video btw
Linus has a video on this, hang on I'll get the link.
I've seen that video, however, my BIOS will not even allow me to adjust CPU voltages/clocks.
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-2714016
Generally the steps are always the same: go to the bios (make sure it's in advanced mode), look for the multiplier options (make sure it's set to manual and not "auto"), then dial in the multiplier value you want (e.g. 45 for 4.5ghz). Apply, reboot, there's your overclock.
sudo chmod -R 000 /*
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-2714099
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-2714137
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-2714271
  • 10 months later...
  • 4 months later...
Yes this still works as of when I got rid of the motherboard. My cpu was running at what I stated above flawlessly under constant stress tests/gameplay. All readings from other programs like HWMonitor, CPUID, System details in CPanel, and BIOS said it was overclocked. The machine seemed faster and the cpu was running perfect. I have a new mobo and cpu now, but at the time this was great for a cheap cpu/mobo combination.
https://linustechtips.com/topic/200223-overclocking-g3258-help/#findComment-6358923
