Hey i m making a new rig want it for heavy gaming mainly for eg: watch dogs, bf4, cod ghosts etc and social usage i have decided
Intel 3.5 GHz LGA 1150 4770K i7 Processor
MSI NVIDIA N760 TF 2GD5/OC (GeForce GTX 760 GAMING) 2 GB GDDR5 Graphics Card
Seasonic M12II-850 850 Watts PSU
Corsair Vengeance DDR3 8 GB (1 x 8 GB) PC RAM (CMZ8GX3M1A1600C10)
Asus DRW-24D3ST DVD Burner Internal Optical Drive
WD Caviar Black (WD1002FAEX) Internal Hard Drive (1TB)
Samsung 120 GB 2.5 inch 840 EVO SATAIII SSD
ASUS Z87-PRO Motherboard
lg 25 inch led backlit lcd - 25um65 monitor
For now i have decided this much i still don't no which cabinet should i use and if any part in the rig is missing and will the above combination?? This is the 1st time i m making a rig and will need help also if possible need suggestion to cut down the cost and any other alternate over the above components which will run things better I m from India currency over here is RS. and my budget is rs 62000 that is 1000$ i have decided for a single ultra wide monitor 21:9 and i dont need any keybords o mice i already have so please help.
https://linustechtips.com/topic/199898-help-regarding-seting-up-a-new-rig/
Hi Dizador. If you are going for a 120GB SSD and 1TB WD Black, you might as well check the WD Black² dual drive. It combines the speed of the SSD and the performance of the WD Black HDD, so it's a perfect fit for a gaming rig. Although note that you will probably need a mounting set, because the drive is 2.5".
Here's a link where you can check all of its features: http://www.wdc.com/en/products/products.aspx?id=1190
Let me know if you have any questions.
Boogieman_WD
WD Representative
http://www.wdc.com
@Dizador sorry, but I can't give you country specific information for where you can find the drive. There's probably a reseller in your country from where you might be able to find the WD Black² drive. About the mounting set, it's somewhat of a "drawer" for your drive which makes it fit in the slots in your case. The slots most cases have are usually for 3.5" drives and this one is 2.5".
Boogieman_WD
WD Representative
http://www.wdc.com
Boogieman_WD where can i get that drawer??
JohnTevor its 62000rs and a lot of parts r not available in India so want it according to that so if u can help it will be great Robbertz thanx for d advice but i would like to stick to that processor and yes i will get a lower PSU around 650
Boogieman_WD
WD Black seems a pointless indulgence if one is getting an ssd. The savings by getting a WD Blue or Seagate Barracuda can go towards a larger ssd. An option that will further enhance overall performance.
brob have got a lot of bad reviews for both
You need to preface the username with '@' for it to do any good.
I have seen good and bad reviews for WD Blue, Black, and Green along with bad reviews for Barracuda. I would be interested in any hard data you have concerning drive reliability of any of these drives when used as intended.
@brob, actually this is not a bad idea at all. With a bigger SSD it's easier to make a compromise with the HDD and either WD Blue or equivalent HDD should work fine with this build.
@Dizador, the mounting set (or mounting kit) is usually not something difficult to find. It should be available in most stores selling PC parts.
WD Representative
http://www.wdc.com
