i5 4670K overclocking help
Solved by Faceman,
Ok thanks, I´ll just go ahead and try it out
You are perfectly fine with a 500W PSU. Your system when stressed to the max, when both the CPU and GPU are overclocked is only pulling ~350W.
Here are some good guides for overclocking:
First, familiarize yourself with the terminology
Load Line Calibration Explained
USE MANUAL VOLTAGE WHEN STRESS TESTING!!!
