Need help with RAM
No I don't live near a Microcenter shop but I do live near a computer shop, Memory Express. I just saw that video btw right before the other reply that's why I figured 1866 is good enough, but then there's the CL stuff so I don't know if CL9 or 10 and I don't know which frequency-CL is good. I do understand the lower is better and the calculation part but I don't know if there's a specific range of frequencies within that CL.
Its simple, you divide the first number of the CAS by the frequency. Thats it. The lower the number, the better/faster the RAM.
I like to multiply the number I get by 2000, to make it a larger number which is easier to read. example: (9 / 1600) * 2000 = 11.25
Here are some common ones:
1600 / 9 = 11.25
2133 / 10 = 9.37
1600 / 7 = 8.75
1866 / 8 = 8.57
2133 / 9 = 8.43
2400 / 10 = 8.33
2400 / 9 = 7.5
Find the RAM that has the aesthetic you want, that is not very expensive. The differences between the RAMs is so minimal, it is not noticeable. If you ever do a multi GPU setup, then higher frequencies will give you better results. If all you do is gaming, you only need 8GB of RAM.
