System not booting
Solved by toastdude123,
that will be the RAM problem
remove the button battery from the mobo for 5 mins
then place it back
run again with 1 stick and swap with the other
if the above fails
most likely the RAM are fried
Will i be able to get this returned and sent out new ram from PNY( http://www.pny.com/8GB_(2x4GB)_PC3-10666_1333MHz_DDR3_Notebook_SODIMM?sku=MN8192KD3-1333 )
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
2
derekchan ·
Posted in New Builds and Planning7 -
5
4
7
kerriya ·
Posted in Cases and Mods10
play_circle_filled
Latest From ShortCircuit:
