Help with sshd not being recognized
Go to solution Solved by Aniallation,
so I found disk manager and the disk but when i right click it it says convert to dynamic disk, or convert to mbr disk
Could you possibly get us a screenshot? nvm found out what you were talking about
You want to right click on the blue or black part, not the part that's says Disk 0, Disk 1, etc
The part that says Healthy or Unallocated
If it says Healthy, right click and choose Change Drive letter and Paths, then choose one of the letters
If it says Unallocated, right click and create a new partition
I recently bought the seagate laptop sshd 1000gb i have a laptop with 2 different ports for disk drives. So I installed it and when i turned my computer on it was not it under Devices and drives. I went to device manager and there it was under disk drives but i still don't see it in file manager.
Halp
https://linustechtips.com/topic/199296-help-with-sshd-not-being-recognized/
Halp
Welcome to Linus Tech Tips!
Check Disk Management (Right click This PC -> Manage and it will be on the left) and see if it's there. It may be unallocated space. In this case just right click on the unallocated or unpartitioned space and create a new partition.
"Rawr XD"
Go to disk management, you most likely need to format the SSHD and partition it.
Computer management > Disk Management > Right click on the drive you want to see and then click 'Assign drive letter'
"Rawr XD"
well should I make it a simple volume?
  NVM I got it and that you soo mcuh
