Right so I'm not a tek person at all but have a nice new pc with a corsair 600t case. The CPU is cooled with a corsair 100i with the red mounted to the top.
I would like to liquid cool my gpu using an nzxt kraken bracket for use with a CPU cooler.
So here's the problem. I want to keep the 200mm fan in the front of the case and I don't think there is enough clearance between the exhaust grill and the h100i rad to fit a 120 rad even with the fan pulling from outside.
Now for the question. Is it possible to fit the rad and fan to the back of a drive cage? I know this will push hot air onto the psu and gpu again but I don't see any other options.
If anyone has the answer I would be great or if anyone has any other ideas or advice that would be great.
Thanks guys :)
https://linustechtips.com/topic/199069-gpu-water-cooling-problem-with-space/
