I just recently upgraded a brand new system.
Old system. i5 2500, z68 mobo, 1x 680+, 8gb ram 600w power
My new system seems to be okay, but whenever i benchmark it or run demanding games like BF3 Ultra on 1600p, it crashes a LOT more easily. I can't reach the core clock of what i could have on a single GTX 680 without crashing.
New system: I7 3820, Extreme9, 2x 680+, 32gb ram. 850w 80+ gold power.
Same OS and everything.
Can anybody help explain why?
https://linustechtips.com/topic/1987-problems-with-680-sli/
Seasonic X-850 80Plus Gold 850W
I don't think it's the heat, it's around 62-65 degrees C. Which is similar to my single 680.
Although for some reason, both gpus don't go idle anymore and are at 1006 all the time as opposed to 380 something for non heavy use.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27060
I have no idea how i posted in some weird format.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27061
Probably when you copy-pasted the first part about the PSU.
Dude, honestly, I'm racking my brains trying to think of what possible issue this could be.
What motherboard are you using? Are you positive everything on the hardware side is fine? That seems more likely the issue.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27091
Seasonic X-850 80Plus Gold 850W I don't think it's the heat' date=' it's around 62-65 degrees C. Which is similar to my single 680. Although for some reason, both gpus don't go idle anymore and are at 1006 all the time as opposed to 380 something for non heavy use.[/size']
Aside from the thermals, i've got nothing. Your PSU's a quality unit. Your temps are fine. Is there another system you can chuck the cards in and SLI? That'll rule in or out the cards. If it isn't them, then it's down to your CPU or motherboard. Possibly something wrong with a PCI slot and a very remote chance there's something wrong with your PCI controller in your chip or though I don't see how that can happen.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27093
I guess you could try making sure your cards are both on PCIe 3.0 x16 slots. That shouldn't matter, but at this stage you might as well do it anyway.
Make sure your PCI 6-/8-pins are connected properly.
SLI bridge in place properly? Seriously, that's the whole hardware side of it, I can't think of what software issues there could be.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27102
It crashes when above 1241 Mhz on Almost anything. Heaven, 3dmark11 and all games.
The absolute most it can do before crashing was 1254mhz (no crash but it was on breaking point)
Previously i could get up to 1301 mhz while doing 3dmark 11.
A little more info: The GPUs are EVGA 680+ FTW Editions. (Both of them) and they are both running on x16 slots.
I use precision X and sync them together for the OC.
There is one thing though, my psu has the option of 4x 8pin connectors but i had to use 8 for the CPU already.
I instead use 2 molex to 2 6pin adapters (In parallel).
I also have the molex connector thats on the MOBO which is located just above the PCI slots Not in use.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27107
2x8 for cpu*
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27108
Have you tried not overclocking them? 1240 is a pretty high OC, really, and if you have two you could probably get ultra @ 2.5K without overclocking.
https://linustechtips.com/topic/1987-problems-with-680-sli/#findComment-27112
