Spec:
ASUS M5A99X Evo r2.0
CPU: amd 6300
CPU cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835106235
Im having problem about the mounting, the two screw doesnt reach the plate
I tighten everything, im afraid that if i force it, it'll just damage the mobo or mybe my cpu
Help please
ASAP currently building
https://linustechtips.com/topic/198384-mounting-cpu-cooler-problem/
Do you have any pictures?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Read the manual again. Sometimes the backplates are reversible and one side is for AMD and the other is for Intel.
If you flip it around it might work!
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
http://tinypic.com/r/30vhrmd/8
http://tinypic.com/r/dos8js/8
here the plate FRONT http://tinypic.com/r/hvch8n/8
back plate comes with a foam http://tinypic.com/r/foorur/8
im getting the hyper 12, i took this one since they out of stock, they told me i can use this one once they get the hyper 12
The one on the top - where the screw is currently in.
which one should i flip? the front? i think it will just makes it work
