Hello
I have some problems with the speed of my notebook cpu
Ive tried to narrow down a couple of things because It started right after I put my laptop into hibernate. for some reason my cpu goes from the standard 3.0 ghz back to 800 mhz and it keep switching in voltage between 1.6 v and 0.7V every 30 seconds Ive tried to reset/update my BIOS but that does not seem to fix it. it started off as having lots of fps drops in game I normally played at 60 fps steady.
Also tried to change the cpu speed to 100% in both powersource and on battery... I also tried to delete my hiberfil.Sys
https://linustechtips.com/topic/19802-laptop-cpu-speed-problem/
have you checked your temps, it could be thermally throttling?
is there a in windows performance mode that you can set it to?
HAF-x,  silverstone op1000, 4670k 1.28v 4.3ghz,  gigabyte g1 sniper z87,  gskill ares 1866 2x4gb,  EVGA gtx 970 FTW 1518/7800, ocz vertex 4 128gb, seagate SSHD 2Tb
https://linustechtips.com/topic/19802-laptop-cpu-speed-problem/#findComment-235957
