Hi guys! Norwegian tech-head here. I was thinking about building myself a computer, but I don't know what parts make the best bang for the buck in my case! I have been following the LinusTechTips channel for about half-a-year now, and since I need a new computer (the laptop I have is totally ruined) I thought I might build one for myself. Computer parts are very expensive in Norway (about 20-30% more expensive than in the US), and my budget isn't the biggest.
IMPORTANT PART STARTS HERE: I want a computer that works fairly good now, but that is easy to upgrade without buying a lot of new parts other than the ones I actually need, that why some of the parts I have chosen might seem a bit overkill compared to other. THIS is the computer I was thinking of building.
Can someone help find the right parts for me, without paying to much extra?
https://linustechtips.com/topic/197987-first-time-builder-seeking-help/
Get i5 instead of that G processor.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
Well the Pentium CPU you chose is not that great and i'd recommend something like an I5 instead, rest should be fine.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
The reason for me choosing that was the video Linus made on how he thought it performed well considering the price, but an i5 is probably better, yes. Thanks for your input!
The Pentium is good for lower end builds, with your 770 the I5 just fits in better :)
I don't think a dual core pentium is a good choice you would definitely want an i5.
Also the power supply is a little overkill i think an EVGA 750w would be good even if you SLI your 770 in the future and it's almost half the price.
Also i think the H100i isn't needed just yet, maybe just get a hyper 212 evo and then use the money saved from the power supply and the cooler to buy an i5.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
Something like a 4670K, or 4690K then?
Yeah that should be just fine :)
budget?
uses?
os?
peripherals?
please read before posting
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
Specs
Here is what i recommend it's a little bit cheaper than your build but has a 4690k which will overclock really well so it will last you a while, Plus a 780 as well.
Motherboard: Gigabyte GA-H97-GAMING 3 ATX LGA1150 Motherboard  ($103.66 @ Newegg)
Memory: Corsair 16GB (2 x 8GB) DDR3-1600 Memory  ($130.00 @ Amazon)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card  ($449.99 @ Newegg)
Total: $1247.59
Generated by PCPartPicker 2014-08-15 08:04 EDT-0400
budget?
uses?
os?
peripherals?
I'm sorry for not writing all details. It's a bit hard saying what budget I have, since the Norwegian prices are so different for the American. I'd say my budget is about 10.000 NOK, but that doesn't help you at all! I want my computer to used mostly for gaming, but also general use like browsing, but I'm getting a cheap laptop for school etc., so again, this computer will be used mostly for gaming. I haven't decided on an OS, plus I didn't think that was neccesairy, since my main priority is the hardware components. I already have all the peripherals I need.
roughly how much is that to usd or could you link a store you will be using
Specs
10.000 NOK is about 1700 USD, so my budget in USD will be about 2100, granted parts are about 20% more expensive. I will be using komplett.no for buying my components, unfortunately it's all in Norwegian
These prices are in USD By the way,
CPU Cooler: Cooler Master Glacer 240L 86.2 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($144.99 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive  ($111.99 @ NCIX US)
Video Card: Gigabyte GeForce GTX 780 3GB WINDFORCE Video Card (2-Way SLI)  ($499.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($103.35 @ Amazon)
Total: $2130.90
Generated by PCPartPicker 2014-08-15 09:24 EDT-0400
With your budget of $2100, I included a 4790k, water cooler, 780s in sli and an ssd. The case is pretty baller too. Hope you like it!
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($329.99 @ Newegg)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2400 Memory ($92.99 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($137.63 @ Amazon)
Power Supply: Cooler Master V850 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($139.99 @ Newegg)
Total: $2130.90
Thank you for your input! I will check how much this costs in Norwegian currency!
Total: $2130.90
