Well im stuck. Here's how its going so far
First i name the topic
http://i.imgur.com/VY3EmqE.png
Then i do " Manege Topic Pooll"
http://i.imgur.com/zLsvP73.png
Then I click finish
http://i.imgur.com/hxHTOtJ.png
And then nothing happens
http://i.imgur.com/TUq0eUQ.png
Specs: AMD FX 6300 @ 4ghz, Asus R9 270 OC, 8gb Corsair xms3, Cooler Master GX 550w PSU, WD 500 blue, Gigabyte  GA-970A-DS3
https://linustechtips.com/topic/197454-how-do-i-post-a-poll/
I don't think it's supposed to show anything on the editor page, if you have any data in "Manage Poll", the poll will be created.
It says "You must enter a post."
https://linustechtips.com/topic/197454-how-do-i-post-a-poll/#findComment-2677712
You're creating a post with the poll attached to it. The poll has its own name (don't ask me why). Just copy the name of the poll into the topic name field and you should be ok.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/197454-how-do-i-post-a-poll/#findComment-2677719
