So, recently my friend's mom's laptop died, and she got a new hard drive for it, because that is typically what goes in a computer
But, I visited yesterday, and nothing came out of it. It turns out the motherboard was dead. But, end of that story
So, I have a couple of oldish laptops laying around, so I decided to fix one up and give it to her.
I currently have an HP G72 laying around.
I tried to plug it in, and turn it on.
Currently, the lights turn on, and then 2 seconds later, it turns off.
It doesn't make any beeps. The fan turns on during that 2 seconds as well.
The thing doesn't have a hard drive, but I don't think that is the problem
I took out the RAM to see if that would help, but it doesn't; same results
I don't think the motherboard is dead, because the CPU heats up, and it charges a battery
Any suggestions?
https://linustechtips.com/topic/196869-oldish-laptop-problems/
I'd suggest that you put one stick of RAM in and the hard drive - if that doesn't work, it's probably dead.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/196869-oldish-laptop-problems/#findComment-2669873
