Extremely Low GPU Temps (Broken Temp Sensor?)
I think I may have broken a temperature sensor on my GPU.....
I was playing BeamNG.Drive when suddenly™ my driver crashed.
This is what showed up after my driver crashed. You can tell when the driver crashed.
Windows 8.1 64-bit
Intel Core i5-4670K
GA-Z97X-Gaming 3
8 GB (2x4 GB) Kingston HyperX Grey
Asus DCUII GTX 580
CX600M
 BIOS : Ver. F3
https://linustechtips.com/topic/196714-extremely-low-gpu-temps-broken-temp-sensor/
Well the temperature sensor seems to be working fine when the card is under load so at least you know you load temps. Idle temps are not as important.
Simple Stryker (Now Finished  ;) )
The Terrible HP
You live in Alaska or something?
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
