Need Amp/Dac help
Go to solution Solved by Guest,
It could be the type of music i listen to. Mostly metal(along with all sub genres of it) rock and alternative. But my no means am i saying i'm not happy with them. Just wondering if i could get something more out of them is all really.
Volume could explain the "something missing" feeling. Increasing the volume will increase the amount of bass and detail that you perceive, so it wouldn't hurt to grab one of the mentioned amp suggestions IF you don't have enough volume currently.
So im using Beyerdynamic DT 990 pro headphones, and my on board sound. They do not sound bad by any means, but i feel like they are missing something, also the max volume is a bit lacking. For on board sound im using Gigabyte 990-fxa-UD3 motherboard.
My budget is around 100$ it can be stretched if needed, Just posting here to see what people will recommend.
https://linustechtips.com/topic/196651-need-ampdac-help/
The Fiio E10K is the succesor to the e10 which is great and it's still great HERE
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/196651-need-ampdac-help/#findComment-2667728
If you have $100 to blow, I say go all-out and get the monoprice desktop amp: http://www.monoprice.com/Product?c_id=120&cp_id=12008&cs_id=1200801&p_id=11567&seq=1&format=2
That said, if "something is missing", it's hard to say if an amp will do anything about that. It could just be that the Beyer DT 990 aren't quite your cup of tea and it would be a shame to spend $75+ if that is the case.
https://linustechtips.com/topic/196651-need-ampdac-help/#findComment-2667798
not really, just more volume.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/196651-need-ampdac-help/#findComment-2667943
https://linustechtips.com/topic/196651-need-ampdac-help/#findComment-2667951
