Serious help needed
Go to solution Solved by EYCEthebest003,
Its fixed.
I separated the raid and put the mobo into AHCI, then it detected the drives and i was able to repair the MBR.  I put the mobo back into raid and now we're back into windows.
Thanks for your suggestion TheKDub, i appreciate it, even though i didn't have to use it.  I'm glad it all worked out.
Im troubleshooting a friend's computer that suddenly wont boot.  Every time we try to boot normally it launches startup repair which fails to work.  I tried a few commands in cmd like fix MBR and whatnot but i kept getting an error message.  I popped in a windows 7 disc to do a repair install and it wont detect any disc drives.  Bios detects both his HDD and SSD
He is running intel SRT with a 1TB WD Black and a Kingston SSD
bios shows that his drives are still raided together
his motherboard is a gigabyte a z87m-n3h
Corsair Obsidian 800D | Msi GD-80 z68 | Intel Core i72600k (stock speeds at the moment) | Msi Gtx 570 twin frozr III | 8GB Corsair Dominator @1600mHz | Coolermaster evo 212 temporary) | Cooled by Gelid Wings | Intel SRT smart caching | Windows 7 ultimate x64
https://linustechtips.com/topic/196076-serious-help-needed/
try making a windows 7 repair flash drive?
https://linustechtips.com/topic/196076-serious-help-needed/#findComment-2659590
will this accomplish anything that using the bootrec tools wont?
https://linustechtips.com/topic/196076-serious-help-needed/#findComment-2659605
Its fixed.
https://linustechtips.com/topic/196076-serious-help-needed/#findComment-2659642
