I have an core i3 3240 cpu with a GTX 550ti. Motherboard is MSI H61M-E33/W8. I am trying to utilize Intel QuickSync with OBS. So following the directions from this link https://obsproject.com/forum/threads/intel-quick-sync-is-beautiful-and-the-future-of-streaming.7597/
When I get the iGPU's drivers installed, it quickly gives me a BSOD error that indicates the iGPU. Is there anyway to help me install it the drivers correctly without blue screening on me.
Diamond Cube https://pcpartpicker.com/b/wvPscf
Diamond 2.0 The FX Rev 2.0 http://pcpartpicker.com/p/Z6sMLk
The only Ryce that can Make It Shine Gamer plus a Student Games,Tech,and everything in Between. Showing all Love to@victoriajustice
https://linustechtips.com/topic/195532-nvidia-gpu-and-intel-hd-igpu-quicksync-help/
What's quicksync?
Its Intel's recording program, allowing you to put the load of recording or streaming video on to your CPU's integrated GPU. That way it doesn't decrease the performance of your dedicated GPU.
OP, as to your issue. Do you have any information regarding the specific error it is giving you?
i7 2600K @ 4.7GHz/ASUS P8Z68-V Pro/Corsair Vengeance LP 2x4GB @ 1600MHz/EVGA GTX 670 FTW SIG 2/Cooler Master HAF-X
http://www.speedtest.net/my-result/3591491194
The BSOD Im getting is from this igdkmd64.sys forgot what else it said after that. Googling that says its the intel drivers . I am running Windows 7 if that matters
