Hi guys!
3Ds Max Vray rendering + Autocad + Adobe + Games (More on 3Ds Max)
Budget : USD 2000+
I'm going to overclock my cpu,
below are my plan, I just need the box, please suggest me~ what to up and what to down.
MAINBOARD ASUS MAXIMUS VI EXTREME
CPU CORE I7 4790K (4C/8T)
RAM 1866C9 VENGEANCE PRO 8GB x 2
SSD PLEXTOR M6 PRO 256GB
HDD BLUE DESKTOP 1TB
GPU ASUS GTX780 STRIX 6GB D5 384BIT OC
POWERSUPPLY RM1000 ( A/M/80+)
CASING CARBIDE 500R
CPUCOOLER NH D15
https://linustechtips.com/topic/195249-3ds-max-vray-games-rig/
The motherboard is overkill, you could save some money there, and maybe spend on more ram.
Also, that rig will use a maximum of 500-600 watts, so the power supply is also overkill.
INTEL I7 4790K @4.6Ghz |  ASUS Z97-A  |  CORSAIR Vengeance Pro 1866Mhz 16gb | NVIDIA GTX 780 | NZXT H440 White | CORSAIR RM750 | SAMSUNG 840 EVO | WD Caviar Black 1TB | LIQUID COOLED |
https://linustechtips.com/topic/195249-3ds-max-vray-games-rig/#findComment-2648105
Hi, Thanks!!! , Any suggest on a cheaper and a good quality motherboard, and for power supply and suggestion ?
and for spend more on ram mean? what to suggest? and what extra ram helped on ?
https://linustechtips.com/topic/195249-3ds-max-vray-games-rig/#findComment-2648163
