Anything is possible if you put your mind to it. Practicality is a different issue
https://linustechtips.com/topic/194966-is-this-possible-help/#findComment-2644120
could you do it though because i normally dont go on my desktop because the graphics card isn't good enough so i use my laptop but i would like a bit more power and i use my laptop more anyway now
https://linustechtips.com/topic/194966-is-this-possible-help/#findComment-2644165
you can but, you need a laptop with express card adapter and i think there is a speed bottle neck also so its not really practical.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/194966-is-this-possible-help/#findComment-2644686
