I was trying to install Java (latest Version) on my computer when it crashed. When I try to launch a program that uses java it says that the registry points to a nonexistent version. I Tried re-installing java but the problem still stands. I tried using the Microsoft fix it program but it didn't work. Please help me and thanks
https://linustechtips.com/topic/194801-java-registry-problems/
go to add remove programs remove all instances of Java.
Reboot.
Install a 32 bit version of Java first then install the 64 bit version.
Then try your application again.
Good Luck.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/194801-java-registry-problems/#findComment-2644407
