That's too high for this particular CPU, even if it was on load. Try reapplying thermal paste and double check if the fans are spinning. On a FX series CPU you typically don't want to go above 60 degrees or else thermal throttling kicks in.
My rigs:
NEW Ryzinator build:
CPU: AMD - Ryzen 9 3950X 8-Core Processor
Motherboard: Asus - PRIME X370-PRO ATX AM4
RAM: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 @ DDR4-3066
Storage: (3x) Samsung - 850 EVO-Series 500GB 2.5", Samsung - 960 EVO 250GB M.2-2280
PSU: Seasonic Prime TX-750
OS: Microsoft - Windows 10 Pro 64-bit
Additional fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan
Case: Fractal Design - Define R5 (Black) ATX Mid Tower Case
GPU: ASUS Radeon RX 580 Dual OC 4GB
Display: MSI 27L Optix MAG272QP @ 165Hz
OLD Build (SOLD):
CPU: AMD FX-6100 Motherboard: ASRock 960GM/U3S3 FX (VRM overheating, don't buy) RAM: 8GB Kingston ValueRAM GPU: Onboard ATI Radeon 3000 Graphics Case: Corsair Obsidian 500D Storage: Hitachi HDS721010CLA332 1TB, 119GB SAMSUNG MMCRE28G5MXP-0VBH1 (SSD), 465GB Western Digital WDC WD5000AZRX-00L4HB0 (SATA)  PSU: Be quiet! - Straight Power 10 400 Watt Cooling: Cooler Master Hyper 212 EVO OS: Windows 10 Pro x64
Retro gaming build:
CPU: Intel Pentium 3 Coppermine @ 800MHz Motherboard: Asus P2B i440BX BIOS 1012 FSB: 133 MHz RAM: 1x 128MB Hynix PC133 SDR SDRAM GPU: ATi Radeon 9200 256MB AGP Case: Full Tower case (unbranded) Storage: CompactFlash card to IDE converter (16GB card) Sound Card: Aztech 2320 ISA Cooling: Stock heatsink fan OS: Windows 98 Second Edition
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2627906
I took out the regular thermal paste that came with it an put some arctic silver 5 ( pea sized shape) and yes fans are spinning
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2627928
You might want to check in the BIOS if the CPU voltage settings are set to auto and the memory settings are set to spec according to the manufacturer. Also, turn on the Cool 'n quiet function if it isn't already.
If none of this works, I don't think I can help.
My rigs:
OLD Build (SOLD):
Retro gaming build:
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2628002
is it possible that the BIOS temps are wrong I haven't installed windows yet to download my own temperature thing like speedfan
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2628248
It's possible, but unlikely. Maybe you can check the manufacturers website for BIOS updates, if there's an update you should check the changelog to see if the update might resolve the issue.
Or you could try and feel the heatsink or the airflow that comes from it to see if it really is that hot. You will definitely be able to tell de difference between 30 degrees C (what my FX-6100 runs at in idle) and 60.
If it doesn't actually feel that hot it is relatively save to say that the BIOS can't read the thermal sensor properly.
My rigs:
OLD Build (SOLD):
Retro gaming build:
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2628597
it doesn't actually feel that hot and I can't update my drivers yet because I'm still waiting for my OS cd to come in but I will as soon as I get my cd
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2629181
You can usually update the BIOS within the BIOS. No need for an OS. What motherboard do you have?
My rigs:
OLD Build (SOLD):
Retro gaming build:
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2632596
i have an msi 970a g43
I have the same motherboard, the CPU temps in bios are fudged in my opinion; they don't show that high within windows. The most recent bios update for it, is version 10.3 from 28-03-2013. I have no idea how you got hold of this particular motherboard recently though, it has been discontinued for around 5 months or so; you must have picked up some very old stock. I hope it only cost you like £20, it was only £50 when I got mine over a year ago.
My FX-4300 is currently running at 25c, and gets to max of 50c with the most intense of usage. This is using the stock cooler also.
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2632942
I got my motherboard for $50 from newegg really glad to hear that the temps are possibly wrong going to download speed fan as soon as I get windows installed to check the correct temps
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2632972
My temps in the bios are just as high as yours.
I just checked neweggs uk side of things, the MSI 970a G43 is still £41, thats insane for how old it is. With the age of the MSI 970A G43, I would have personally gone for an MSI 990FX-GD65 for that price (at uk pricing right now). If I was in the USA, I would have gone for the Asrock 990FX extreme3. That one is currently $99 on newegg USA.
Still, it is a good motherboard; not had a single issue with mine at all. It should serve you well.
https://linustechtips.com/topic/193864-cpu-temp-please-help/#findComment-2633016
