i am debating myself for cabinet, which pc cabinet and PSU shud i buy ?
my config is: i7 4770k
8 gigs kingston hyper
1 tb HDD
H87 gigabyte
my budget for pc case is around 50 - 75$
and PSU budge i don't know.
also, i m in India,
so i have this brand available here called Circle, Power Hub is normally comes along.
but i would like suggestions on should buy this or look for another ? would be really helpful..
http://www.circlect.com/index.php?route=product/product&product_id=229
http://www.circlect.com/index.php?route=product/product&path=67_89&product_id=172
thank you.
https://linustechtips.com/topic/193504-cabinet-help-plz/
yeah, its a Case, in India we usually use Cabinet word for it. jsz local thing
well it does come with inbuilt PSU 450 W like iBall, i m using iBall from 5-6 yrs with no issue.
that said, i never really went on doin some research for it, so now i know there are better options available,
can be costly but little raise in budget is fine, as long as its not too much.
many people use it here, even my trusted engg tell me it's fine, has no issue.
but i would like to keep better options open. so i need help.
http://www.flipkart.com/cooler-master-k281-mid-tower-cabinet/p/itmdmhz9agn5fqat
i've this pc case in mind, not sure about PSU though, which to buy.
also forgot to mention : i7 4770k,
H87 gigabyte
1tb WD HDD
8 gigs Kingston hyper
gtx 750ti or 750 GPU
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623029
H87 gigabyte
1tb WD HDD
Do you already have these parts or are you looking to buy them? Also quote so I can see your replies!
Quote me to get a reply!
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623057
ya, i will get them in 2-3 days,
why is there any issue with them ? plz tell me.
There are not the best choice of parts because you can get better gaming performance with an i5 and a better GPU. What is your budget in rs?
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623071
well, i am in need of i7 4770k, its not for gaming only, but also i require it for Rendering 3d scenes and vfx videos.
so that's also necessary for me, sometimes editing 2k vids.
can u plz xplain why its not best choise of parts ?
i mean which are wrong ? plz tell me.
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623082
If you need to render video then I understand why you are going for the 4770K. A problem is the motherboard it will work with the CPU but you won;t be able to overclock. I would buy a Z87 motherboard, something like the MSI Z87-G43 for a good well priced motherboard. In your editing are going to be using CUDA? If not then AMD GPUs would offer better gaming performance for similar prices.
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623117
thank u for this info, i never knew this.
so what you are saying is if i use H87, ii won't auto overclock ? bcz i am not sure what u really mean.
would u plz give me little bit more insight ? like does h67 auto OC ? like  z87 ?
and if we do manual OC does both motherboard work ?
also, would u plz tell me about PC case thing too ?
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623192
Overclocking is a feature of the chipset. You need a Z series chipset to overclock. For the 4770K the Z87 or Z97  is required to overclock. The coolermaster K281 that you linked the before would be fine.
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623205
say i am not plannin on OC ing, then H87 is fine right ?
can ask u little bit more ?
If you don't plan to OC then H87 is fine, also if you are not going to OC a 4770 be a better choice because it is cheaper and you are not going to overclock anyways.
https://linustechtips.com/topic/193504-cabinet-help-plz/#findComment-2623224
