corsair 350d radiator compatibility (front 360)
hi all,
i'm trying to do a little bit of planning for my upcoming water cooled 350d build and have not been able to find anything related to this topic.
ive seen plenty of atx cases modded to fit a 360mm rad but none on the 350d or any other mATX cases.
i'm obviously completely open to do as much modding as is required although i do 'not' want to have to cut into the exterior of the case.
i can see it being a tight fit because the case can nativly fit a 280 and 240 rad in the front, so if 3 x 5.25 = 1 x 120mm then it might just fit..... but of course the 350d only has 2 x 5.25 bays...hmmmm????
You will easily be able to fit a 360mm Rad in the front if you do not plan on using your 5.25" bays, it might be a bit tight to have a 240 in the top along side a 360 though if you wanted to have one
Just cut out a section in the 5.25" bay (https://dl.dropboxusercontent.com/u/97695353/Temp%20photo%27s/IMG_2374.JPG This is what I did to a previous build)
, or take the whole entire thing out and put the 360mm rad in.
