4k gaming?
Case:Define R4 | MOBO:ASRock z75 Pro 3 | CPU:i7-3770k 4.0GHz | CPU Cooler:H100i | GPU:970 Strix | RAM:Hyper X 16GB |
Peripherals:ATH-M50x Limited Blue Edition | K95 RGB | M65 RGB | Blue Yeti MIC | (3x)1920x2080 Acer Monitors
https://linustechtips.com/topic/192676-need-help/#findComment-2611085
I'd get 2 290x's then water cool em.
I can game at 5760x1080 with a single 290x if I turn down my graphics.
https://linustechtips.com/topic/192676-need-help/#findComment-2611102
i dont trust my self to water cool D:
Then I don't recommend the R9 290x since it gets quite hot. Maybe if you got the Vapor tho.
Actually get two r9 290x then two 780's. Mantle support coming with some big games.
Don't buy the Titan Black if you're just gaming.
https://linustechtips.com/topic/192676-need-help/#findComment-2611116
Not only will you get better performance for ~$40 less ((titan black=$1099) - (2 X 780=$529) = $40), but 3GB on the 780 is plenty enough vram for a while for 1080p, and even 1440p for a bit, 6GB on the titan black is just useless right now. Except for Watch_Dogs....darn you watchdogs......
*cough* the EVGA SC 780's are epic *cough*
                                           i7-4770k @3.5GHz | 2 EVGA gtx 780 SC ACX in SLI | AsRock Xtreme4 z87 | Corsair XMS3 DDR3 1600 | Corsiar HX-850 | NZXT Phantom 410 |        CoolerMaster Siedon 120XL AIO Water Cooler | X-Star 1440p 27"
https://linustechtips.com/topic/192676-need-help/#findComment-2611155
hmmm ok
2 R9 290x will cost just a bit more than 2 780's but the mantle support for games like GTA V, BF4, and Sims 4 is worth it. Unless you want Nvidia features like idk game streaming?
https://linustechtips.com/topic/192676-need-help/#findComment-2611189
i would get the R9 290xs but i really want g-sync and shadow play
AMD has game DVR which to my knowledge is just as good or even better(don't quote me on that) but yeah G-Sync is something we currently don't have. Seeing as you are spending buttloads of cash on GPU's you don't mind spending the extra cash on some G-Sync monitors.
https://linustechtips.com/topic/192676-need-help/#findComment-2611212
Actually the only way i can pay for it is my dad helping me out (my frist time) Also whats Dvr????
https://linustechtips.com/topic/192676-need-help/#findComment-2611305
any good 290x's??
Game DVR is AMD's version of Shadowplay.
https://linustechtips.com/topic/192676-need-help/#findComment-2611449
