Hello Im building a computer and i have a question
Comp specs:
GPU: gtx 780
CPU: i5 4690k
MOther Board: MSI ATX 1150 Motherboards Z97 GAMING 7
Ram: Kingston HyperX FURY 16GB (2x8)
Heat sink: Corsair H110 280mm liquid cooler
OD: LG BD-ROM Blu-ray
PSU: Corsair RM Series 650 Watt ATX/EPS 80PLUS Gold-Certified
Case: Phanteks Enthoo Pro Full Tower
OK so i was wondering if my psu will have enough watts to handle an overclock. I was thinking something around 4.0 - 4.5.
Thank you!!
https://linustechtips.com/topic/192659-building-a-pc/
It will be fine, yes.
https://linustechtips.com/topic/192659-building-a-pc/#findComment-2610814
Yep, its fine
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/192659-building-a-pc/#findComment-2610824
Shouldn't have much trouble but definitely cannot do SLI if you want to do that in future
  • CPU:  AMD Ryzen 7 7800X3D
  • Motherboard:  MSI PRO B650M-A WiFi
  • RAM:  G.Skill Trident Z5 RGB 32GB (2 x 16GB) DDR5 Memory @ 6000MHz
  • Graphics:  Colorful iGame GeForce RTX 3070 Ti Ultra W OC 8G-V
  • StorageKingston KC3000 2TB M.2 PCIe NVMe Gen4 SSD; Seagate Barracuda 2TB Hard Disk Drive @ 7200rpm
  • PSU:  Cooler Master V1000 1000W 80+ Gold
  • Case: Corsair 4000D Airflow
  • Keyboard: Cooler Master CK550 RGB Mechanical Gaming Keyboard w/Gateron Red switches
  • Mouse: Glorious Model O- Wireless @ 1600dpi, 1000Hz
  • DAC: JDS Labs OL DAC
  • AMP: JDS Labs O2 AMP
  • Headphones: Hifiman HE-400I w/ZMF Ori Lambskin pads
  • Soundbar: Creative Sound BlasterX Katana
  • Monitor 1: BenQ EL2870U @ 3840 x 2160, 60Hz
  • Monitor 2ASUS Predator XB252Q @ 1920 x 1080, 240Hz
  • Monitor 3AOC G2460 PQU @ 1080 x 1920, 144Hz
https://linustechtips.com/topic/192659-building-a-pc/#findComment-2611480
