mobo update required for devils canyon cpu?
Go to solution Solved by TheMcSame,
It should work out the box. The Z97 chipset supports both Haswell and Haswell refresh CPUs as well as the upcoming Broadwell CPUs.
Hi, i'm getting the Asus Z97-A + Core i5 4690K. Will the new haswell refresh cpus work on this mobo out the box or do I have to update it? Will the mobo post on the first boot because it wouldn't have the new BIOS update to add compatibility for the new Devils Canyon CPUs?
Thanks
CPU+Cooler: Intel Core i5 4690K @ 4.5GHz + Corsair H105 (Getting custom loop soon)  GPU: EVGA GeForce GTX 970 SC  RAM: Kingston HyperX Fury 8GB  Motherboard: Asus Maximus VII Hero  PSU: Corsair AX860i  Case: Corsair Graphite 760T Black
https://linustechtips.com/topic/192542-mobo-update-required-for-devils-canyon-cpu/
ok, thanks for your reply :)
Z97 Should work right away with the Devil Canyon CPU's.
ZEUS
CPUi7 4770K - 4.4Ghz CoolerNoctua NH-D14 MB: Maximus VI Hero RAM4 x 4GB Vengeance Pro DDR3 2133Mhz GPUWindforce 780ti Case: Corsair C70 Storage: 3 x 128GB 840 Pro SSD in RAID 0 , 2 x 1TB Barracuda PSU860W AX860i Displays: Asus VG248QE 144Hz , Asus VE247H 60Hz KeyboardRazer Blackwidow 2013 MouseRazer Deathadder SoundSennheiser HD 558 Mic: Blue Snowball
"If I'm not quoted I probably won't reply back to you."
