I'm choosing between 3.
Sennheiser PC350 that has a microphone included ofc.. Sennheiser HD558's that don't come with a mic, or Audio Technica ATH-M50(x)?
I want something thats definitely durable and will last me quite some time, has great sound quality and good for gaming, and if I go for the 558's, a good mic that I may get.
Any ideas?
https://linustechtips.com/topic/192522-headphone-hunt-help/
558 and a blue snowflake maybe?
Had a blue snowball, Wasn't impressed.
And I'm not looking for a desk mic, I'm looking for something that I can comfortably sleep in.. This is an odd thing to say, but I'm in an LDR and we fall asleep together on skype every night.
https://linustechtips.com/topic/192522-headphone-hunt-help/#findComment-2608788
you clearly messed up the settings then because those are amazing, and yes.. thats odd :P and no idea....
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/192522-headphone-hunt-help/#findComment-2608805
If you're looking for something that you can comfortably sleep on, then don't use an over-ear headphone. Who would want to sleep with something a bit heavy on their head? Get an in-ear headset. Right now I'm using a Skullcandy 50/50, but it's not something that I'd sleep on. It's like a fortune here in my country, not some cheap headset like some Americans might think.
If you insist on getting an over-ear. Get the HD558 or the ATH-M50 (preferrably M50x), a detachable mic for headphones (like the ones Linus did a video on before), and then a cheap in-ear. Besides, if it's Skype you don't need a high quality headphone. Skype makes sound quality from a high quality mic sound shit.
Toshiba Satellite C50 (A167)
  • Intel Pentium 2020M (Ivy Bridge, IHD 3000)
  • 8GB DDR3 (4x2)
  • 500GB Toshiba Slim 5400RPM
  • Win10 Pro x64
Huawei P8 (GRA-UL10)
  • HiSilicon Kirin 935 (arm64)
  • Android 6.0 (EMUI 4.0, TWRP 3, Sysless SuperSU)
  • 3GB RAM, 64GB NAND + 64GB SanDisk Ultra mSD
https://linustechtips.com/topic/192522-headphone-hunt-help/#findComment-2608984
