AMD
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.73 @ OutletPC)
Motherboard: Gigabyte GA-F2A88X-UP4 ATX FM2+ Motherboard  ($89.99 @ Newegg)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($109.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ NCIX US)
Total: $672.58
Generated by PCPartPicker 2014-08-05 12:34 EDT-0400
Intel
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($184.98 @ OutletPC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($34.78 @ Amazon)
Total: $697.62
Get Windows 8.1 from G2A for $18
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607857
for gaming only? get a AMD FX cpu
for $700 including OS($100)
start with my pc build, get a AMD FX-6300 instead of mine
and then instead of the gpu i have, get a GTX 770 or a R9 280x for around $250
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607858
What cpu is better, Fx-6300 or i5- 5560?
i5, you can't go wrong with an i5...
INTEL I7 4790K @4.6Ghz |  ASUS Z97-A  |  CORSAIR Vengeance Pro 1866Mhz 16gb | NVIDIA GTX 780 | NZXT H440 White | CORSAIR RM750 | SAMSUNG 840 EVO | WD Caviar Black 1TB | LIQUID COOLED |
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607898
I mean i5 4460
And would this cpu be good for video editing a bit?
To a certain extent yes it will, for heavier video editing an i7 is ideal (but that might be outside of your budget). For video editing I would not recommend AMD personally.
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607962
I mean i5 4460
Not too heavy editing, but it could handle a bit :)
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607965
i just threw this together im sure there are better options but hey just spend some time on pcpartpicker
CPU: Intel Core i3-4330 3.5GHz Dual-Core Processor  ($129.99 @ Amazon)
Motherboard: Gigabyte GA-B85M-D2V Micro ATX LGA1150 Motherboard  ($49.79 @ Newegg)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($74.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.91 @ OutletPC)
Video Card: Gigabyte GeForce GTX 650 Ti 2GB Video Card  ($162.98 @ SuperBiiz)
Case: Rosewill FBM-01 MicroATX Mini Tower Case  ($23.98 @ Newegg)
Power Supply: CoolMax 400W ATX Power Supply  ($22.47 @ Amazon)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($104.51 @ NCIX US)
Total: $621.62
Generated by PCPartPicker 2014-08-05 12:47 EDT-0400
corsair 600t, msi z87-g45, intel 4770k, 16g patriot viper low-pro ram, asus direct cu2 780, crucial 256gig ssd, seagate baracuda 1tb,
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2607992
gotcha...careful with that budget stretching next thing you know your lookin at sapphire 290x and figuring out how long you can go without paying your electric bill before they shut you off lol
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2608141
https://linustechtips.com/topic/192467-pc-build-help/#findComment-2608232
