I recently buy a Gtx 760 OC from MSI (the nongaming edition) that gpu have a code to get any free game from nvidia ? or is just 770 or above ?
CPU: Intel Core i7 4770k | Motherboard: Asus vi Hero | RAM: Kingstong hyperx fury 16GB (2x8GB) 1866Mhz | PSU:XFX PRO 850w  | STORAGE: WD 1tb blue | COOLER: Corsair H100i CASE: NZXT phantom (black and green) OS: Windows 7 ultimate  (64bit) | VGA : Asus DCU II 780 | Other stuff : Razer Deathadder 2013 edition - Blackwidow Ultimate 2013 - Razer Kraken pro - Razer Goliathus control L - LG 23' IPS full HD
https://linustechtips.com/topic/192420-help/
Like the other two said, depends on where you bought them, if you don't have a code, you could ask the store itself if they're offering that, if not and you want free codes I suggest you contact Nvidia :)
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/192420-help/#findComment-2607170
