I got some Logitech X530 5.1 surround sound speakers plugged them all in and they work when testing using windows sound but they wont work in DTS Sound which is my sound card all the sound just comes threw the 2 front speakers
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/192206-51-speaker-problem/
What sound card do you have? Right click your quick launch icon for sound and choose playback devices. Make sure the speakers are chosen as default device and configured for 5.1 surround sound.
i7-3770K @ 4.5GHz, ASRock Z77 Extreme4, G.Skill Sniper 8GB DDR3 1866 @ CL9, ASUS GTX 780, CM HAF XM, Samsung 850 Pro 256GB, WD Black 1TB x 2, EVGA SuperNOVA G2 850W, BenQ XL2420TE 24" 144Hz @ 1080p, CM Nepton 280L, Noctua Industrial IP67 2000RPM 140mm PWM Fan x 6
https://linustechtips.com/topic/192206-51-speaker-problem/#findComment-2606487
U need to understand, Music is stereo so they will come throw Front Speakers, try playing some games like Crysis or a newer DVD. U will hear 5.1 surround. & also make sure that u setup your sound manager well. Most common motherboards have Realtek HD manager, double click it & set to 5.1 on speaker config section, & also right click on volume icon on task bar & click playback device & set it to Realtek Audio.  Hope that helps.
https://linustechtips.com/topic/192206-51-speaker-problem/#findComment-2607507
