Help! I tried to oc my 4770k to 4.2 ghz. I stability tested on manual and verified that my cpu is stable at 4.2 at 1.125 vcore. But when I switch to adaptive mode, my motherboard completely disregards my set voltage and bumps the voltage up to 1.22 when my cpu is under stress. I am aware you cant stress test with adaptive voltage, but this happens when im playing games, and doing other real world things that stress the cpu out.
note: if I put the voltage to anything higher than 1.22 the cpu will give that exact voltage under load.
i7 4770k
asus gryphon motherboard
gigabyte r9 290
corsair h100i
antec 620 watt psu
8gb corsair ram 1600mhz
what I did in the bios
asus oc tuner: swithced it from auto to xmp
cpu core ratio: switched it from auto to sync all cores
set multiplier to 42
set voltage to adaptive
defined additional turbo voltage to 1.125 (that automatically set "total turbo mode voltage" to 1.125)
https://linustechtips.com/topic/192008-overclocking-problems-with-voltage/
For people using the night theme;
i7 4770k
gigabyte r9 290
corsair h100i
antec 620 watt psu
ZEUS
CPUi7 4770K - 4.4Ghz CoolerNoctua NH-D14 MB: Maximus VI Hero RAM4 x 4GB Vengeance Pro DDR3 2133Mhz GPUWindforce 780ti Case: Corsair C70 Storage: 3 x 128GB 840 Pro SSD in RAID 0 , 2 x 1TB Barracuda PSU860W AX860i Displays: Asus VG248QE 144Hz , Asus VE247H 60Hz KeyboardRazer Blackwidow 2013 MouseRazer Deathadder SoundSennheiser HD 558 Mic: Blue Snowball
"If I'm not quoted I probably won't reply back to you."
Why don't you just keep adaptive mode off?
ZEUS
