I was wondering if anyone could direct me towards the best 780 in their opinion. I don't know if I should go with an EVGA OC'd one or a Gigabyte OC'd one.
If someone reccomends me going with AMD or a different Nvdiaia card (please leave all biased opinions out) for my $1,500 build, please tell me. This will be my first build from scratch and by far the most powerful computer I've had.
All feedback is appreciated.
Edit: I plan on having a 3-4 monitor set up (all 1080p) within the next two years for anyone wanting information on the display
        I also would like to play common FPS games (BF4, CS, etc) at maximum settings (excluding heavy v-sync settings)
PC: Ryzen 2600X, EVGA 1080 DT, Gigabyte X470 Aorus Gaming 5 WiFi, Corsair 2x8GB DDR4 3000Mhz, EVGA SuperNOVA G2 750W 80+ Gold, Phanteks  Enthoo EVOLV ATX
Peripherals: Logitech G502 HERO, Cooler Master ML510, Corsair K68 Cherry MX Red, Dell S2417DG YNY1D 24" 165HZ G-Sync 1440p, Acer XF251Q,
Audio: AKG K7XX, JBL SLR308 MKI, Scarlett 2i4 (2nd Gen), Sony MDR-7506, Shure SE-215, Audio-Technica AT2020
Server: Dell Poweredge T420 running ESXi, Hosting Plex and Automation services and misc. game servers; 2x Xeon E5-2400, 32GB ECC Memory, ~40TB Storage (Mix of SSDs and HDDs)
Network: Asus RT-AC3100 (Current), Supermicro running pfsense, 10/100/1000/10000 Netgear Switch
https://linustechtips.com/topic/191968-help-choosing-my-graphics-card/
If someone reccomends me going with AMD or a different Nvdiaia card (please leave all biased opinions out) for my $1,500 build, please tell me. This will be my first build from scratch and by far the most computer I've had.
Whats your budget on your gpu?
780 Windforce
290 is better price to performance.
Since it's a $1,500 build, I was thinking any where from $400-$550.
Could anyone direct me to an AMD vs Nvidia help page? Or should I make a new thread concerning the two options?
Thanks for all the feedback! :D
I would suggest getting the EVGA GeFORCE GTX 780 6GB. It will cost you a little bit more, but it's 3 gb more (which is definitely not needed for now, but a great for futureproofing.) !
Thanks! I will look into the 6 GB model (I was unaware there was one).
