I've never actually knew the proper estimation but I know some exists, I already have 2 hooked up to my 780ti, getting another right now. So what are we looking at here?
ZEUS
CPUi7 4770K - 4.4Ghz CoolerNoctua NH-D14 MB: Maximus VI Hero RAM4 x 4GB Vengeance Pro DDR3 2133Mhz GPUWindforce 780ti Case: Corsair C70 Storage: 3 x 128GB 840 Pro SSD in RAID 0 , 2 x 1TB Barracuda PSU860W AX860i Displays: Asus VG248QE 144Hz , Asus VE247H 60Hz KeyboardRazer Blackwidow 2013 MouseRazer Deathadder SoundSennheiser HD 558 Mic: Blue Snowball
"If I'm not quoted I probably won't reply back to you."
https://linustechtips.com/topic/190946-how-much-of-a-decrease-in-fps-per-monitor/
Well it's going to be 50% more pixels to drive, I'm not sure if that exactly scales to fps though. I'd say its going to be a lot more than 1/6 less. And I'm assuming you're going to be having the game on all three monitors?
If the monitors are just displaying an idle desktop, there's really no difference at all. The only difference you would see is if you were running programs that use GPU power alongside your game.
i7 not perfectly stable at 4.4.. #firstworldproblems
Would be interesting to know if you are going to game on all three or just game on 1 and have the other 2 for workstation purposes. But in your sig I see this is a 144Hz monitor. If you are going to game on three of those you probably will have to buy another GTX 780Ti in order to get good FPS.
I use 2 monitors. A 27" Dell 1440p @ 60 Hz for gaming (will be replaced with the Asus Rog Swift) and a Samsung 23.4 1080p. But the second monitor is just as side gimmick. I use it to surf or watch youtube clips while gaming or monitor my hardware with it. In terms of performance, I don´t even feel that it´s there. Didn´t run specific benchmarks for that but I think it isn´t really a big deal.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
if gaming on multiple the single monitor performance can probably just be divided by number of monitors although it's not really a accurate representation.
If only one monitor is running a game and the other(s) is just displaying say Google tabs or your steam library performance decrease is very unlikely to be found, any real decrease will come from you have running in the other monitor(s). I can't run BF4 on one screen and the BF4 active battlelog map of the multiplayer game im playing on- the extra load of the live map is too much more for my i5 to handle and so my BF4 lags quite a bit.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Sorry all, I should of added that I will be gaming on my 144hz monitor, while the other 2 will have Facebook or Youtube or something along those lines open.
ZEUS
Youtube might impact the performance depending on the rig, hard to say if you will see a difference especially with your PC, maybe 10% just an estimate from my set up but my i5 can really be downer in some games with youtube open and playing a video.
the fps won't change*.
*well, not by a meaningful amount anyway. An idle desktop won't affect it at all, so play a youtube video on one of the two monitors while the other is gaming and see what your fps is. It will be pretty much identical.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
In that case I don´t see any issues at all that you will loose a lot of performance. You should be fine. And anyways you will stress with that multi tasking more your CPU than you GPU. But with a 4.4 GHz clocked 4770K no problem ;) .
Perfect thanks for the information guys!
ZEUS
